1. AC Question's Avatar
    they are so expensive, I am hoping the last a log time
    06-20-2015 12:25 AM
  2. Darksurfr's Avatar
    life as in what? battery life? years of use?
    I would guess that you could easily, if not draining it completely dead all the time, get about 4 years with good use out of the battery.
    Years before need/want for an upgrade I would say about 3 but it is all a personal thing. anything more then 2 and I start to get antsy. you could go longer but personally I find anything longer then a year on a stock Cell provider rom needs to be thrown out and put something cleaner, less demanding and less bloat on the phone. Then they operate a lot better and have you draining the battery less. once you find a good stable setup it could last a long long time.
    06-20-2015 12:40 AM
  1. Replies: 1
    Last Post: 06-21-2015, 08:52 PM
  2. Replies: 1
    Last Post: 06-21-2015, 08:47 PM
  3. Replies: 2
    Last Post: 06-20-2015, 03:29 PM
  4. What would happen if I downloaded the wrong firmware for my phone?
    By Oscar Contreras265 in forum Samsung Galaxy S5
    Last Post: 06-20-2015, 03:05 AM
  5. My HP With windows 8 won't recognize my Galaxy S6 Edge, Why?
    By Sophialwsn in forum Samsung Galaxy S6 edge
    Last Post: 06-19-2015, 11:35 PM
