1. goldencore's Avatar
    I'm just being careful because last time my tablets charging port broke and i cant use it anymore thanks!
    06-21-2015 08:35 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    I would say look for these issues:
    -Plug is no longer snug or tight.
    -Charging slows down
    -If you have sounds, you get random disconnects and reconnects.
    -Device becomes warmer than normal.
    06-21-2015 08:41 AM
  3. Mooncatt's Avatar
    These are all also symptoms of bad USB cables too, which are more likely to go bad than a port. If you start having those problems, don't automatically assume it's a port issue.
    06-21-2015 09:15 PM
  4. Golfdriver97's Avatar
    Very true.
    From my G4
    Android Central Ambassador Team Leader
    06-21-2015 09:20 PM
  1. Is there an app for tracking all my routes?
    By Jurij Fedorov in forum Android Apps
    Last Post: 06-30-2015, 10:10 AM
  2. How do I remove an Amazon ad from my Turbo main screen?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 06-23-2015, 10:54 AM
  3. Should i upgrade to a new phone?
    By vrael101 in forum Ask a Question
    Last Post: 06-21-2015, 09:41 AM
  4. Several issues in my phone!!?!
    By Faamac in forum HTC One M8
    Last Post: 06-21-2015, 08:34 AM
