1. Chrisy's Avatar
    Is this possible on Android? Is it easy? I do a lot of copying and pasting on my BlackBerry. Thanks!
    01-15-2011 07:36 PM
  2. terpitude71's Avatar
    its in there, but admittedly, its one of the weaker functions on android. some devices can do it better than others. any device that you have a d-pad or trackball will be able to do it a little easier, but you unfortunately wont find it as easy as it is on BB.
    make sure you check out the intro thread linked in my sig. it will help you out a lot introducing you do the basics in android
    01-15-2011 10:46 PM
  3. Chrisy's Avatar
    Thanks for the heads up! And I will check out that link too.
    01-16-2011 11:48 AM
  4. RHChan84's Avatar
    If you have a rooted phone Copy Paste It works good.
    01-16-2011 11:49 AM
