1. Thatguyyouknow49's Avatar
    I don't want to use my data, which is off, so I'm trying to connect to McDonald's Wi-Fi. The phone says obtaining IP address then says avoided weak connection. I turned that off and tried again. It did the same thing. The connection goes back and forth between good and excellent. I have a Motorola droid mini.
    06-24-2015 10:10 AM
  2. the tall guy's Avatar
    there isn't really anything to advise unfortunately. By the sounds of it, the public wifi in McDonalds wherever you are is weak or too many people are using it.
    06-24-2015 10:49 AM
  3. FiveOverEight's Avatar
    Or the Wifi is crappy in McDonalds? - They may even have a fault? - Have you asked them?
    06-24-2015 12:00 PM
  4. the tall guy's Avatar
    That's what I said - the WiFi is weak. Also I didn't ask the question so I can't ask McDonald's
    06-24-2015 12:44 PM
  5. Thatguyyouknow49's Avatar
    That would make sense (too many people) but when it first started there were around 5 other people. Thanks anyway.
    06-24-2015 01:04 PM
  6. Rukbat's Avatar
    "Too many other people" usually means in excess of 200, unless they've set a smaller limit in their router. It might be the phone. Bring it to your carrier's store where they do repairs and ask if they can try connecting it to their wifi. If that doesn't work, it's not McDonald's, it's the phone.
    Does it connect okay to your home wifi, and stay connected when you walk one or two houses down the block (it should).
    06-24-2015 06:03 PM
  1. I have a 350L ROM and need to change it to D838
    By m.seif in forum LG G Pro 2
    Last Post: 07-17-2015, 08:47 AM
  2. Replies: 1
    Last Post: 06-24-2015, 11:05 AM
  3. When will I get the Lollipop update for my S4 on T-Mobile?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 06-24-2015, 11:03 AM
  4. Why does it show no Network when paired to Note 3?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 06-24-2015, 10:08 AM
