A
AC Question
Hi everybody,
I just copied my whatsapp folder from my old telephone to my new one and after this, I installed whatsapp on my new telephone. I've copied the folder with the files on the same spot as where they were on my old phone, so I thought whatsapp would find them. But no, this is not the case. My question is now: where should the folder be on the Sony Xperia3Compact with android 5.0.2?
I accidentally threw away the new whatsapp folder on my new phone and there now doesn't seem to be another folder (yet, probably it will be there after a back up?). I can't look it up myself for this reason and I would like to know it asap.
Can anyone with the same phone have a look where the whatsapp folder is located?
On my old one it was on this path: /storage/emulated/0/
Thank you very much!!!
