Re: why my sd card is not detected
Nothing at all?
Have you tried re-inserting it.
Have you gone to Storage. Can you select Mount sd card.
What device do you have? Did you formerly have another card in the device?
Can you see the sd card in the device when connected to a pc via usb.
