1. AC Question's Avatar
    i have lost my mobile contectsdue to factory reset kindly advise for recovery
    06-27-2015 10:55 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Were the contacts associated with your Google account (which would have synced automatically to your Google Contacts in the cloud) or with the local Phone Account (which doesn't sync anywhere)? If the former, then go to Google Contacts on the web and see if your contacts are there. They should sync back to the phone once you log in with the same Google account.
    If they were saved only to the local Phone Account, then they're gone. This is why I always recommend that people not use this account.
    06-27-2015 11:25 PM
  1. Replies: 1
    Last Post: 06-28-2015, 12:43 AM
  2. How can I set my sd card as a primary storage?
    By AC Question in forum LG G3
    Last Post: 06-27-2015, 11:34 PM
  3. Replies: 1
    Last Post: 06-27-2015, 11:31 PM
  4. How do I fix the TouchWiz Home from constantly stopping???
    Last Post: 06-27-2015, 11:29 PM
