1. AC Question's Avatar
    I have an Android Phone, a Newer one, when I bought it, the Manufacturer said it could handle up to 64GB SD card, so that's what I bought. I loaded the SD Card it Detected it, and automatically loaded the Android Software on the SD Card. Everything was working Fine I was using it everyday, I had loaded lots of MP3 Files on it, and was loading Videos on it and all kinds of stuff. I had entire Folders of Playlists, planing to use it as a DJ Device in certain situations. I was working fine, then all of a Sudden the Phone would no longer Recognize the SD Card, would not even SEE it. The First time it happened I tried Formatting the Card using the Computer and then Reinstalling it in my Phone that didn't work, the only thing that DID work was I Wiped it out with a Magnet, then it worked fine again. Then the Same Problem occurred. So I thought maybe the SD card was bad, so I bought a whole new 64GB SD card, it worked fine for about a Month, then the same problem happened again. I thought it was a Virus, but I am beginning to suspect it is a Bug in the Android Software OS itself. Because I have seen so many Android Users being affected by this same problem. I am thinking of Installing Ubuntu on my Phone. Does anyone have enough knowledge out there to comment on this issue?
    06-28-2015 02:30 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    What phone do you have?
    07-01-2015 11:57 AM
  1. Replies: 1
    Last Post: 06-28-2015, 12:43 AM
  2. Replies: 1
    Last Post: 06-27-2015, 11:40 PM
  3. How can I set my sd card as a primary storage?
    By AC Question in forum LG G3
    Last Post: 06-27-2015, 11:34 PM
  4. How do I fix the TouchWiz Home from constantly stopping???
    Last Post: 06-27-2015, 11:29 PM
  5. Android auto vs Hyundai infotainment
    Last Post: 06-27-2015, 10:52 PM
