1. unit_shifter's Avatar
    Having a samsung s1 captivate i897 (yes OLD) at&t branded cell phone that was 100% paid for, but never unlocked back in the day.
    Trying to unlock now to use as a second line, but REFUSES TO ACCEPT the codes from AT&T.
    The phone is useless if left on at&t (whose reception sucks in the big city and doesn't even work in the house) and i've got one attempt left to try to input the right code - with no idea why it hasn't worked so far.
    If I could reset the carrier unlock limit using root or something else, this would make it alot easier of course. I'm very new to all this phone modification stuff btw.
    06-28-2015 11:10 PM
  2. Rukbat's Avatar
    You mean the number of tries to unlock it? You need the PUK code (also from AT&T). Bring it to the store, ask them to put the PUK code into it, then the unlock code.
    06-29-2015 12:02 AM
  1. How do I uninstall 360 security from my Samsung 2 cell phone?
    By AC Question in forum Samsung Galaxy S2
    Last Post: 01-03-2018, 11:40 PM
  2. Anyone go back to iPhone after giving the s6 a try?
    By KelseyRo4 in forum Samsung Galaxy S6
    Last Post: 07-30-2015, 09:14 AM
  3. Any apps or settings to adjust the physical power button?
    By stocktrader240 in forum HTC One M9
    Last Post: 06-29-2015, 08:36 AM
  4. reset '5of5' carrier unlock counter??
    By unit_shifter in forum AT&T Captivate
    Last Post: 06-28-2015, 11:06 PM
  5. S5 connects to PC but can't view any files.why?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 06-28-2015, 10:21 PM
