1. AC Question's Avatar
    When I touch my volume key it goes from super loud to no volume without slowing down. How do I slow down the speed of the volume key, it goes from loud to off with one touch?
    06-29-2015 09:59 AM
  2. srkmagnus's Avatar
    What device are you using? The volume should increase and decrease in increments. Are you able to adjust the settings via the settings > volumes menu?
    06-29-2015 11:59 AM
  3. B. Diddy's Avatar
    Instead of holding it down, just tap it multiple times to go down stepwise.
    06-29-2015 12:40 PM
  1. Volume boost app or mod without root
    By ddonahueiup in forum LG G2
    Last Post: 10-17-2016, 09:58 PM
  2. Can't take screenshot uses volume/power button
    By camelot023 in forum LG G4
    Last Post: 07-17-2015, 09:09 PM
  3. Settings or app to adjust the stupid power button??
    By stocktrader240 in forum HTC One M9
    Last Post: 06-30-2015, 07:18 PM
  4. Volume warning
    By THE POTZ in forum Samsung Galaxy Note 4
    Last Post: 06-29-2015, 12:49 PM
  5. Any apps or settings to adjust the physical power button?
    Last Post: 06-29-2015, 08:36 AM
