1. Solo Black1's Avatar
    Samsung galaxy s4 not starting up and keeps flashing it's logo over and over again.
    I pull out the battery and inserted it again after few minutes it remain the same flashing.
    I connected it to a power outlet and it will nor charge, rather still flashing on the screen showing Samsung galaxy s4 and not turning on.
    I tried to press the power button + the home key and the volume key, it shows a command in the screen and ask to press button up to continue, when I did press the volume button up to continue, it will return to the flashing screen.
    Am frustrated.
    06-29-2015 10:01 AM
  2. srkmagnus's Avatar
    Welcome to the forums. You can try clearing cache from the Recovery menu using the same button configurations mentioned in your post. If that doesn't work then try a factory reset.
    06-29-2015 11:56 AM
  3. Solo Black1's Avatar
    I have done the 2 mentioned options and still the same thing is occurring.
    06-29-2015 11:46 PM
  4. DavidR123's Avatar
    Hi, do you find a solution? my I9500 have the same issue. Displays "Samsung Galaxy S4 GT-I9500" over an over, I try to long press power button, and nothing, I try to "power+home+volume up" and display the screen for a second then restar with the same S4 logo.
    07-17-2015 08:34 PM
  5. ckkhoo's Avatar
    I think most of not starting up and flashing are related to the faulty power button. Here's the link you can follow on how to troubleshoot the power button if it's working properly or not using a voltmeter.
    07-28-2015 05:32 PM
  1. Replies: 2
    Last Post: 07-14-2015, 12:14 AM
  2. Galaxy Note 4 Water Damage
    Last Post: 06-29-2015, 06:15 PM
  3. AT&T Samsung S5 data problems
    Last Post: 06-29-2015, 12:42 PM
  4. How do I slow down the speed when adjusting volume levels?
    Last Post: 06-29-2015, 12:40 PM
  5. Remove debris stuck between screen and frame?
    By Tactical Squirrel in forum LG G4
    Last Post: 06-29-2015, 09:36 AM
