I'm thinking of switching from Windows Mobile to Android. One of the things which drives me absolutely up the wall with windows mobile phones is the Network login screen. About half the time when the phone drops data connectivity the Network Login screen pops up. If you have activesync or any application that depends on a constant or semi constant data connection you might as well reset the phone as that window will pop every second no matter how you try to stop the data session, and until it finds a new session the phone is dang near unusable. Is there any such annoyance as this on the Droid Phones? I.E. if you drop connection will it just display an icon or what not, or does it also have its own set of "screen loops" that just wont go away?
Thanks
Thanks
