1. AC Question's Avatar
    my goodness, we have tried to block the ex from texting and calling, the only option we can find it auto reject and spam but the msgs and calls still come through, ANY IDEAS
    06-30-2015 10:00 AM
  2. Crashdamage's Avatar
    You can do it with Advanced Call Blocker:
    https://play.google.com/store/apps/d...d.call.blocker
    Android since v1.0. Linux user since 2001.
  3. Golfdriver97's Avatar
    Welcome to the forums. Have you called your carrier? They should be able to block a specific number. Otherwise, you should be able to block the number within the phone app. I would put the device in Airplane mode, and then in the history under the menu (most likely) should be a block option.
    srkmagnus likes this.
    06-30-2015 10:06 AM
  4. Mooncatt's Avatar
    Try contacting your carrier. They should be able to block a number, but it may be for a limited time or charge you. I think there are apps to help this too, but I haven't used any.
    06-30-2015 10:06 AM
  5. Crashdamage's Avatar
    06-30-2015 10:12 AM
  6. srkmagnus's Avatar
    As suggested above, the carrier is your best bet when it comes to blocking a particular number. They'll be able to block incoming calls and texts from that number, which should carry over to another device should you switch phones.
    Golfdriver97 likes this.
    06-30-2015 11:38 AM
  7. kmtm's Avatar
    long press on that person in your contact list, an option to block this user appears.
    06-30-2015 01:47 PM
  1. Hello from someone who likes to best of both worlds
    By Nadir G in forum New to the Forums? Introduce Yourself Here!
    Last Post: 07-17-2015, 03:03 AM
  2. Do Not Disturb/ Blocking mode. HELP
    By Nsh222 in forum Samsung Galaxy S6 edge
    Last Post: 06-30-2015, 04:52 PM
  3. Replies: 1
    Last Post: 06-29-2015, 01:59 PM
  4. My Andriod Galaxy S5's screen won't turn on completely, why?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 06-29-2015, 08:07 AM
  5. Replies: 0
    Last Post: 06-29-2015, 04:42 AM
