1. AC Question's Avatar
    i just purchased the android leveno in pink and it is very glitchy, slow and wont allow me to download any google play apps. do you know why?
    06-30-2015 06:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Do you mean Lenovo? Which model?
    Does this happen on both wi-fi and mobile data?
    Go to Settings>Apps>All, select Google Play Store, and Clear Cache/Clear Data, then Force Stop. Do the same for Download Manager. Now try again.
    If that doesn't work, then go to Settings>Accounts, remove your Google account completely, then add it back.
    06-30-2015 06:58 PM
  1. Replies: 5
    Last Post: 07-20-2015, 05:07 PM
  2. so, does the screen need to be off or not?? (quick charging)
    By hunter777 in forum Samsung Galaxy S6
    Last Post: 07-07-2015, 03:39 AM
  3. Replies: 1
    Last Post: 06-30-2015, 10:33 PM
  4. Replies: 1
    Last Post: 06-30-2015, 06:59 PM
  5. What happened to the site?
    By brandogg in forum Ask a Question
    Last Post: 06-30-2015, 06:21 PM
