1. Bebe Leakes's Avatar
    Hi, I have the lG optimus f7 and have had it for about a year. Today, I realized that my arrow key and menu buttons ( located at the bottom of the phone) weren't responding. Can anyone help with this? would appreciate it
    07-01-2015 11:14 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    07-01-2015 12:10 PM
  1. Whats the only Weather Widget or Date and Time widget that matter?
    By BigCrimsonTX in forum Samsung Galaxy Note 4
    Last Post: 07-09-2015, 04:22 PM
  2. My volume buttons don't work on my phone
    Last Post: 07-01-2015, 12:18 PM
  3. Why Galaxys5 wont display my contacts?
    Last Post: 07-01-2015, 11:28 AM
  4. Replies: 1
    Last Post: 07-01-2015, 11:11 AM
