1. AC Question's Avatar
    I'm having some WiFi issues occasionally after waking up in the morning. It doesn't indicate any WiFi connection at the top bar of my phone, but also won't allow me to browse the internet via data or anything like that. WiFi says it's trying to connect to a network, but never moves on from there, just stuck trying to connect. I tried to reset the WiFi, but it will actually no let me restart it. It lets me turn it off in the WiFi menu, but still shows the WiFi radio is on in the pull-down quick settings tab. Also in the WiFi menu, once I have attempted to turn it off, it will not let me turn the WiFi back on. Also, it won't let me turn on/off airplane mode, so I'm forced to restart the phone itself. It works fine upon reboot.
    Has anybody encountered this issue?
    07-03-2015 09:19 AM
  2. B. Diddy's Avatar
    Duplicate, see responses here: http://forums.androidcentral.com/son...-sleeping.html. Thread closed to prevent parallel discussions.
    extravadanza likes this.
    07-03-2015 01:13 PM
  1. How can I fix my Android OS battery drain after 5.1.1 update?
    By Devendra95 in forum Legacy Android & Other OS's
    Last Post: 01-28-2016, 12:24 PM
  2. Replies: 4
    Last Post: 07-06-2015, 06:00 AM
  3. Android Wear lock screen issues with Zen Watch and Huawei P8
    By Michael Clarke5 in forum ASUS ZenWatch
    Last Post: 07-05-2015, 01:59 AM
  4. Replies: 1
    Last Post: 07-03-2015, 01:20 PM
  5. What data should be backed up before factory reset of s3.
    Last Post: 07-03-2015, 07:09 AM
