1. mrZISS0U's Avatar
    Hi, apologies if this has been answered before. I recently had trouble with my home WIFI; the modem stopped working, they sent out a new modem but when I use any location services on either my PC or android devices it shows a location 3 - 4 hours away. As soon as I leave the house and use mobile data my location updates immediately.
    I searched for other posts online and the suggestion was disabling google location services and then enabling again shortly after but had no luck.
    Any suggestions?
    *As the location updates when i walk outside and shows correctly I called my ISP thinking they could update something on their end but they said they have never heard of this issue before.
    07-03-2015 02:48 PM
  2. Rukbat's Avatar
    Have you checked the time setting in your new router? If it's set to the wrong timezone, it might cause a problem.
    07-03-2015 03:44 PM
  3. gone down south's Avatar
    Houses or hours?
    07-03-2015 04:23 PM
  4. mrZISS0U's Avatar
    The location that is showing incorrectly is still in the same time zone, I live in Birmingham, UK, but it is incorrectly showing as Manchester UK.
    The router is showing the correct time zone.
    07-03-2015 04:32 PM
  5. mrZISS0U's Avatar
    Houses or hours?
    Hours.
    Previously the location was fairly accurate, differing by a few houses which was fine, now it's not even close.
    07-03-2015 04:33 PM
  1. Replies: 4
    Last Post: 07-06-2015, 06:00 AM
  2. Why won't my phone connect to wifi?
    By AC Question in forum Moto G
    Last Post: 07-03-2015, 02:54 PM
  3. Can I get some help with wifi issues after waking my device up?
    Last Post: 07-03-2015, 01:13 PM
  4. WiFi / Data issues in the morning after sleeping.
    By extravadanza in forum Sony Xperia Z3v
    Last Post: 07-03-2015, 01:12 PM
  5. Replies: 1
    Last Post: 07-03-2015, 11:02 AM
