1. AC Question's Avatar
    My phone all of a sudden switched to 2g and since then it doesn't switch to 3g. I have network and everything. The phone itself doesn't go on the WCDMA option. Even if I select WCDMA only it turns to GSM only setting.
    07-04-2015 09:10 PM
  2. Raptor007's Avatar
    Could be an issue with your SIM card, did you update the OS lately if so was it the correct OS update. What phone and carrier are you having issues with?
    Golfdriver97 likes this.
    07-04-2015 09:19 PM
  1. Why won't my Alcatel One Touch Pop C7 connect to my computer?
    Last Post: 07-11-2015, 07:54 PM
  2. International Android phone? Part2
    Last Post: 07-05-2015, 07:09 AM
  3. apps not showing up on playstore
    By southjersey786 in forum Google Nexus 6
    Last Post: 07-04-2015, 08:55 PM
  4. Replies: 1
    Last Post: 07-04-2015, 08:14 PM
  5. Reply to Text problem
    By AirBoyzT in forum LG Watch Urbane
    Last Post: 07-04-2015, 07:44 PM
