1. Alex Lipnevic's Avatar
    How can I find SMSC settings on android lollipop 5.1 ? I have some issues with receiving sms.
    Thanks in advice
    07-07-2015 07:06 AM
  2. shel692's Avatar
    You should be able to find it in the hidden menu. Open dialer and type *#*#4636#*#* That will open the testing menu. Select Phone information, smsc is all the at the bottom. It should appear blank. Taping refresh or update should automatically pull the correct one.
    07-19-2015 04:16 AM
  3. edi151's Avatar
    Having found the SMSC it won't populate when I press Update or Refresh.
    So I put the numbers in manually but then what?
    How do you get it to accept them so they stay there?
    Mine always disappear if I press any other key?
    edi
    09-01-2016 12:24 AM
  4. Reteesh's Avatar
    Thanks in advice
    02-02-2017 10:25 PM
  1. Why does my Z1 turn on after so many days?
    By AC Question in forum Sony Xperia Z1
    Last Post: 07-30-2015, 03:02 AM
  2. Replies: 2
    Last Post: 07-13-2015, 06:36 AM
  3. How can I stop my Samsung S5 crashing on calls?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 07-10-2015, 12:08 PM
  4. Can I get some help with an app called phonebosster?
    By AC Question in forum Android Apps
    Last Post: 07-07-2015, 08:37 AM
  5. Phone turned off and wont turn on
    By Rob Boreham in forum Samsung Galaxy S6
    Last Post: 07-07-2015, 04:52 AM
