1. fanielo's Avatar
    Apps saved in SD card not functioning anymore despite that the icons are still existing.
    It will say, the app is not installed if one clicks on the icon.
    07-07-2015 09:58 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If the error message says the SD card is damaged, then it's probably damaged--as in corrupt. You may have to reformat the card, or use a brand new one.
    fanielo likes this.
    07-08-2015 02:08 AM
  1. Replies: 1
    Last Post: 07-26-2015, 04:54 PM
  2. SMS apps that have quick reply option?
    By justnivek in forum Samsung Galaxy S6
    Last Post: 07-08-2015, 10:32 AM
  3. Replies: 1
    Last Post: 07-08-2015, 02:12 AM
  4. why is my Android phone popping
    Last Post: 07-08-2015, 02:10 AM
  5. How to preview textso on the lock screen for the Gs6?
    Last Post: 07-07-2015, 08:50 PM
