1. AC Question's Avatar
    when i try to take a video it will say 'failure to write file' what could it be?
    07-08-2015 10:27 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The card could be corrupt or counterfeit. Do other cards work?
    Insert the malfunctioning card into your computer and run chkdsk to look for bad sectors: http://forums.androidcentral.com/amb...d-sd-card.html. You can also insert it into the phone and run SD Insight to make sure it's what it says it is. A counterfeit card might claim to be higher capacity than it really is. If the card already is close to its true capacity, then it won't be able to save anything else, even though the system thinks there's plenty more space left.
    07-09-2015 01:58 AM
  3. Rukbat's Avatar
    Also, make sure you didn't tell the camera app (assuming we're talking about Android), to save videos to an existing folder on the card. The app has to create the folder or the device has to be rooted. One app can't write to another app's folder.
    07-09-2015 11:38 PM
  1. Replies: 8
    Last Post: 09-18-2015, 09:01 PM
  2. Why isn't Google photos even listed in my Android Google accounts?
    Last Post: 07-09-2015, 12:40 AM
  3. Replies: 2
    Last Post: 07-08-2015, 10:08 PM
  4. Replies: 0
    Last Post: 07-08-2015, 08:28 PM
  5. Replies: 0
    Last Post: 07-08-2015, 06:52 PM
