1. frozenimage's Avatar
    I have a Asus t700f tablet. It was working fine before I did a master reset. now, whenever it boots up it shows "Unfortunately, the process android.process.media has stopped". That message will open again the moment I close it and can't do much about it because I;m stuck on the part where you have to set up details for the account.
    I tried a master reset again, didn't work and the RCK option (gave me an error and couldn't go through with it). It seems I am out of options and was hoping someone help might help me out?
    07-10-2015 03:54 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you have an SD card inserted? If so, remove it and see if the problem persists. If there's a corrupt media file on the SD card, it might be causing the error.
    07-10-2015 04:48 PM
  1. Unable to Open Wifi Direct on my Samsung Galaxy S5
    By abhay547 in forum Samsung Galaxy S5
    Last Post: 07-10-2015, 03:10 PM
  2. How do I remove an added account on Google but not remove it?
    Last Post: 07-10-2015, 09:03 AM
  3. Replies: 1
    Last Post: 07-10-2015, 06:26 AM
  4. My status bar has disappeared on my HTC mobile automatically, why?
    Last Post: 07-10-2015, 06:14 AM
  5. Very good app to take advantage of edge screen
    By thegame161 in forum Samsung Galaxy S6 edge
    Last Post: 07-10-2015, 03:24 AM
