1. AC Question's Avatar
    On my LG 3 verizon I every time I attempt to open the browser I have this notification from safe-android-protect.com that I have 11 viruses and they want to do a scan, and won't let me do anything else at all. My anti virus says that there are no viruses. Is this a real anti virus or something that infiltrated my tablet?
    07-12-2015 12:45 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Kill that website with fire.
    It's a scareware popup. They're just trying to lure you into installing some bogus "antivirus" app that is itself probably malicious. Try going to Settings>Apps>All, select the browser, and Clear Cache/Clear Data, then Force Stop. Now open the browser again and see if it redirects you again.
    07-12-2015 02:10 AM
  3. CSilver49's Avatar
    I followed the suggestion from B. Diddy and it worked. It cleared all my browser data, I have to start Chrome from scratch again, but it removed the the problem. Thanks
    B. Diddy likes this.
    07-12-2015 09:58 AM
  1. Replies: 1
    Last Post: 07-12-2015, 02:27 AM
  2. Replies: 1
    Last Post: 07-12-2015, 02:20 AM
  3. The power button of my LG F180 is water damaged. Is there anyway to fix it?
    Last Post: 07-12-2015, 02:14 AM
  4. Replies: 1
    Last Post: 07-11-2015, 11:56 PM
