1. Harlan Johnson's Avatar
    Hello folks thanks for attempting to help this is whats going on:
    1) LG Optimus L90 it was recently unlocked from its T-mobile network. I noticed it will connect to the wifi at home but when driving around trying to get gps it don't work (obviously). It fails to send picture texts but regular texts are ok. i tried the settings clicked on the "data enabled" setting nothing works... O the phone was a tmobile now i'm using ATT for the phone.
    07-12-2015 10:57 AM
  2. cabsco's Avatar
    Are you sure the network access point is rightly configured? if yes, i'll suggest you change network band from 3G to 2G Only. It may not support your region 3G network band.
    07-13-2015 08:03 AM
  3. Crashdamage's Avatar
    First, check to see if this is a compatibility problem. You'll need to know the phone's sub-model number. Then go to this site to find out if the phone will work on AT&T. I think it will.
    WillMyPhoneWork.net - Check if your phone works on a network
    If it checks out, contact AT&T tech support. They can set the proper APN info remotely for you.
    07-13-2015 08:24 AM
  1. How do I get my data back?
    Last Post: 07-12-2015, 11:22 AM
  2. Why my keypad phone Lenovo A850 not showed up ?
    Last Post: 07-12-2015, 10:55 AM
  3. Why isn't Make Password Visible working?
    Last Post: 07-12-2015, 10:50 AM
  4. Replies: 0
    Last Post: 07-12-2015, 10:43 AM
  5. How to keep 4G on Samsung Galaxy S5?
    By Rikku Watro in forum Ask a Question
    Last Post: 07-12-2015, 10:40 AM
