1. AC Question's Avatar
    I cant remember my lock code for my phone this has been trouble all I can go to is my guest setting
    07-13-2015 08:05 AM
  2. pvthomas's Avatar
    Try using Android device manager on your computer to change the password on your phone. (Using the lock option) This should change your lock screen password to what you type in on the computer and allow you to get into the phone again.
    07-13-2015 10:18 AM
  3. Neo_ii_Droid's Avatar
    Greetings and welcome to Android Central!
    Just curious to know what phone do you have and do you have a Google Account? If the latter, then here's what I found that should work:
    • Go to AuthSubTokens and enter your login details to see if your Android device is listed.
      If your device is listed, it will be shown as an "Android Phone"
    • Revoke access for the device.
    • Generate a new password.
      1. At the bottom of the page, you will see an option to "Generate New Application-Specific Password".
      2. Enter any name and click on "Generate Password".
      3. A 16-digit password will be generated.
      4. Enter this new password in your Android device, along with the correct Google ID.
    • If the "Generate password" option is disabled, you'll need to enable 2-Step Verification.
    1. Follow the 2-Step Verification link to Google, and set up 2-Step Verification.
    2. Depending on your device, you'll receive options from Google to generate a new password and access your Android device using the 2-Step Verification process.
    Hope all works out for you.
    07-13-2015 04:33 PM
  1. Can't edit nor save contacts in S6
    By MrsCaramella in forum Ask a Question
    Last Post: 07-15-2015, 10:34 PM
  2. Replies: 1
    Last Post: 07-13-2015, 02:34 PM
  3. Why did my Galaxy S6 Edge die completely?
    Last Post: 07-13-2015, 08:04 AM
  4. Why can't I search my corporate inbox in lollipop 5.1?
    Last Post: 07-13-2015, 07:32 AM
  5. Replies: 0
    Last Post: 07-13-2015, 07:05 AM
