1. AC Question's Avatar
    i am using motorola atrix2 Android 4.0.4. It always says all apps not responding! asking if id like to close,how do i fix? And if some times it re switch off and re start itself
    07-14-2015 03:00 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try wiping the cache partition. See if the steps for the Atrix HD work for your phone: https://motorola-global-portal.custh...p/30,6720,8558
    Check to make sure your phone's system if fully up to date. Go to Settings>About Phone>System Updates​, and check for updates.
    07-14-2015 05:49 PM
  1. My 1st App - Quotes Zing - Quotes & Sayings
    By Deepak Pujari in forum Developer Spotlight
    Last Post: 07-22-2015, 01:40 AM
  2. Why is my Xperia SP unable to get full reset?
    By AC Question in forum Sony Xperia Series
    Last Post: 07-16-2015, 05:28 AM
  3. how to update rooted phone?
    By Deante Britton in forum Ask a Question
    Last Post: 07-14-2015, 02:44 PM
  4. Replies: 0
    Last Post: 07-14-2015, 02:38 PM
  5. How to save whatsapp media on sd card in note 3 neo?
    Last Post: 07-14-2015, 02:36 PM
