1. AC Question's Avatar
    Started up phone after buying and it read something about custom os or not. Hit no custom and it's been downloading for 3 hrs. Is there something wrong with the phone?
    07-16-2015 04:38 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it say "Downloading, do not turn off target"? If so, then you somehow booted into Download Mode, which is used to download and install firmware. If you're not connected to anything via USB cable, then the phone isn't actually downloading anything. You could force a shutdown by pulling the battery and waiting 10 seconds. Then power back on by only pressing the Power button. Download Mode is usually accessed by pressing Power, Home, and Vol Down at the same time.
    Laura Knotek likes this.
    07-16-2015 10:55 PM
  1. How do I change time zone on my LG Optimus Fuel?
    Last Post: 07-16-2015, 11:04 PM
  2. Replies: 1
    Last Post: 07-16-2015, 10:58 PM
  3. samsung galaxy note android upgrade
    By Shawn Patton1 in forum Ask a Question
    Last Post: 07-16-2015, 05:32 PM
  4. Are the wooden backs on the MOTO X 2nd gen made of wood?
    Last Post: 07-16-2015, 05:23 PM
  5. Replies: 0
    Last Post: 07-16-2015, 04:16 PM
