1. AC Question's Avatar
    I'm trying to view what all is saved to my sd card and don't know how .
    07-19-2015 05:01 PM
  2. srkmagnus's Avatar
    Welcome to Android Central! You need to download a file manager application, if you don't have one already. There are a lot of good free ones available in the Play Store. I would suggest starting with ES File Explorer: https://play.google.com/store/apps/d...roid.pop&hl=en
    Open the application and look for the internal or external SD card. From there you can view all the contents, including downloaded files. Let us know if you have any questions.
    07-19-2015 07:47 PM
  3. Rukbat's Avatar
    There should be an app already on the phone named ... File Manager.
    07-19-2015 10:09 PM
  1. Replies: 3
    Last Post: 09-23-2015, 03:15 AM
  2. How can I sort apps alphabetically?
    Last Post: 07-19-2015, 07:57 PM
  3. Does Android wear work on flashed version of ROM?
    By Inaho in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-19-2015, 07:55 PM
  4. Why have I 2 of every contact in my contacts?
    Last Post: 07-19-2015, 04:55 PM
  5. Replies: 0
    Last Post: 07-19-2015, 04:48 PM
