1. Tastyboi's Avatar
    I have a Samsung Galaxy S4 GT-I9505. I takes screenshots. And I have organised my picture gallery very well on my SD card.
    However the screenshots are saved on the device memory.
    Does anyone know how to change the location of where the screenshots are saved?
    I would like to change it to the same area I keep all my pictures.
    Glowsticks likes this.
    07-20-2015 04:54 AM
  2. Rukbat's Avatar
    Rewrite the ROM. Where screenshots go is hard wired. (The best you can do is an app like External 2 Internal SD (Root) which mounts your external SD card as sd0, so that everything is saved to the external card by default.)
    07-20-2015 06:20 AM
  3. Tastyboi's Avatar
    Thanks for the advice.
    My phone isn't rooted. And I'd rather it not. I have had rooted phones before, but I can't see the use.
    This method seems rather complex. Instead what I'll do is cut and paste the pics. As that is the only picture method that I can't change to go directly to my SD card. Cut and paste would be a lot easier.
    But if anyone else knows how to change the default save for screenshots to SD card please advise.
    07-21-2015 08:49 AM
  1. [FREE][GAME] Galaxy Conquest II: Space Wars
    By happycamp23 in forum Android Games
    Last Post: 01-12-2016, 04:59 AM
  2. How can I reset my phone without it restoring data?
    Last Post: 07-20-2015, 09:29 AM
  3. Replies: 2
    Last Post: 07-20-2015, 07:35 AM
  4. trying to add new APN; menu button doesn't give 'add' option
    Last Post: 07-20-2015, 06:35 AM
  5. When did I give permissions to my Galaxy Tab3 lite to root?
    By AC Question in forum Samsung Galaxy Tab 3
    Last Post: 07-20-2015, 06:27 AM
