How can I increase the volume in my speakers?
A
AC Question
Speakers volume not too high
How can I get more volume from my speakers ?
All of my coworkers, can hear music at the jobsite using their phones, like Alcatel, LG or Samsugn, and everyone have enough volume to hear the music while the phone is attached to the belt, but I cant here that much.
Thank You
Hector
anon(9555426)
11
Re: Speakers volume not too high
I think you can get a little more volume if you raise all the levels in an EQ. Though it is really just down to the actual speakers hardware.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
The equalizer apps decrease the volume at the frequency ranges you choose - all the way up is the same as not running the equalizer.
The amount of sound you get depends on two things - the power the audio amp puts out and the efficiency of the speaker. You can't change the efficiency of the speaker, you have to replace it with a more efficient speaker.
You can't change the amount of power the amp puts out without redesigning the motherboard.
You could get an external Bluetooth speaker - some of them might be loud enough for you.
kerokekerol
