Why do I get the message Unfortunately System UI has stopped after installing custom ROM?
  • Start date Start date
A
AC Question
I tried to install ViperOne M8 4.3 and after booting it tells me that the System UI has stopped, which renders the phone essentially unusable. I am running the correct firmware (5.0.1) and can verify that through bootloader.
Any ideas how to fix this?
Re: Unfortunately System UI has stopped after installing custom ROM
Welcome to Android Central!
You might need to factory reset to fix the issue. That should get rid of the bad files.
collingsmwale8
