1. AC Question's Avatar
    well it says E and my connection isn't well when I have highspeed data. I have T-Mobile for this device
    07-21-2015 11:49 PM
  2. Laura Knotek's Avatar
    What device do you have?
    Is it branded to T-Mobile or an unlocked device from another carrier that you are using on T-Mobile?
    How is your coverage in the area? Could it be that you aren't getting good signal from T-Mobile where you are at?
    Have you contacted T-Mobile? Perhaps you need a new SIM.
    Are any towers in your area being serviced?
    Crashdamage likes this.
    07-21-2015 11:51 PM
  3. Crashdamage's Avatar
    E stands for Edge, aka 2G data service. You could say E = slow. There's few areas left in the country (maybe none by now) where T-Mobile offers only 2G service. Probably everywhere there's a T-Mobile signal at least 3G service is available.
    2G data service kinda piggybacks on the cellphone (voice) signal. 3G and LTE data service is different, it uses a dedicated data network. Laura is on the right track. Apparently you have no data network signal because of:
    No coverage or the network is down or...
    You have a device not compatible with T-Mobile or...
    You have a SIM problem.
    Are you sure you have a compatible device?
    Have you dialed 611 and talked to tech support?
    Android since v1.0. Linux user since 2001.
    Laura Knotek likes this.
    07-22-2015 09:32 AM
  1. Why a deleted google account keeps sending me notifications?
    Last Post: 07-22-2015, 09:38 AM
  2. Replies: 1
    Last Post: 07-21-2015, 11:48 PM
  3. Replies: 0
    Last Post: 07-21-2015, 11:44 PM
  4. Replies: 0
    Last Post: 07-21-2015, 11:35 PM
  5. Why won't saved pictures from texts show up in my photos?
    Last Post: 07-21-2015, 11:19 PM
