1. Kir Jose's Avatar
    Hello i performed a factory reset on my s3 Verizon running ANDROID 4.4.4 yet am not in the US and now i can not pass by the activation screen.I have tried all possible means as suggested like touching the corners but no success .
    Can someone help me out?
    Thank you
    Kir jose
    07-22-2015 07:46 AM
  2. LeoRex's Avatar
    Have you tried the '4 corners' method?
    On the Language screen (right on the first language) tap top left corner, then top right corner,(above the emergency call and next) then bottom left corner, then bottom right corner, then volume up.
    07-22-2015 12:39 PM
  3. Kir Jose's Avatar
    i tried it out but its ain't working
    07-24-2015 05:37 AM
  1. To buy or not to buy the edge??
    By beckybluecat in forum Samsung Galaxy S6 edge
    Last Post: 07-26-2015, 12:40 PM
  2. Is there a problem with some mapping Apps on the Galaxy Tab 2 10.1?
    By Lundavra in forum Samsung Galaxy Tab 2 10.1
    Last Post: 07-22-2015, 07:36 AM
  3. Why does the home button flash green?
    Last Post: 07-22-2015, 07:17 AM
  4. Replies: 1
    Last Post: 07-22-2015, 06:57 AM
