1. lindz951's Avatar
    I have an HTC one sv and I've tried 3 different sd cards one brand new all either 32 or under and it will not recognize that I even have a sd card in. All it says is memory full or mount sd card when its already in .i can not use my phone for anything other then call and texting that's it. No camera no apps uninstalled all of them. I've tried soft resets and battery in and out and even had my phone off for hours. I've done a bunch of online reading and nothing. I can not seem to find an answer to how to fix it. I've emailed htc numerous times with no reply. Can anyone please help me?
    07-23-2015 03:02 AM
  2. srkmagnus's Avatar
    Try formatting the SD card (FAT32) and try again. You can format it from the device or from a computer - PC or Mac, does not matter.
    Let us know if that helps.
    07-23-2015 09:46 AM
  1. My first Android game on Google Play : TX30
    By hakan aksoy in forum Android Games
    Last Post: 03-19-2016, 04:23 AM
  2. Replies: 1
    Last Post: 07-23-2015, 03:40 AM
  3. Replies: 0
    Last Post: 07-23-2015, 03:00 AM
  4. Replies: 0
    Last Post: 07-23-2015, 02:46 AM
  5. Why is my HTC One sv not recognizing any sd cards?
    By lindz951 in forum HTC One SV
    Last Post: 07-23-2015, 02:25 AM
