1. cvijetin's Avatar
    • Hi
    I have problem with my Wiko cink peax 2. When somebody call me he don´t hear me. But when I talk on Viber everything is ok. He can hear me.
    What can be problem?
    07-24-2015 05:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Perhaps your primary mic is faulty, or the mic opening is clogged by lint or other debris. If your phone has a secondary mic (which is often used for noise cancellation, as well as stereo recording when using the video camera), then Viber might be using the secondary mic. The speakerphone often uses the secondary mic as well--can they hear you if you put it on speakerphone?
    Look closely at the primary mic opening, and see if it's clogged.
    07-24-2015 11:15 PM
  3. cvijetin's Avatar
    No they don´t hear me when I turn on speakerphone. But I think it is mic. When I use headphon with mic they hear me....
    07-26-2015 07:35 AM
  4. B. Diddy's Avatar
    It's probably a defective mic. Did you check the mic opening to make sure it isn't blocked?
    07-26-2015 12:53 PM
  5. cvijetin's Avatar
    It´s definitly mic. But I will open and see is he blocked.
    Can u tell me for what prise I can sell this phone, and what smartphone is low cost?
    I only need Viber,Whatsapp and Wlan. That is only what I need.
    07-26-2015 05:38 PM
  6. B. Diddy's Avatar
    Sorry, but I don't know what that phone usually goes for. If you're looking for a high quality device with a budget price, try the Moto G or Moto E, if available in your area.
    07-27-2015 01:19 AM
  1. Replies: 2
    Last Post: 09-22-2015, 08:07 AM
  2. Replies: 3
    Last Post: 07-31-2015, 10:50 PM
  3. Replies: 1
    Last Post: 07-25-2015, 12:03 AM
  4. USB port is a tank!
    By 88horizon5speed in forum Motorola Droid Turbo
    Last Post: 07-24-2015, 05:38 PM
  5. What can I do if my Fitbit surge screen is cracked
    Last Post: 07-24-2015, 04:58 PM
