1. Adnan Ali4's Avatar
    i want to remove the built in wallpapers from android OS. tried many techniques in root explorer but still unable to find the exact method of removing these wallpapers.
    07-25-2015 04:33 AM
  2. hiterus's Avatar
    bro, try to put a black image as wallpaper.
    Dont think there is a "none wallpaper" setting on Android
    07-25-2015 04:38 AM
  3. Adnan Ali4's Avatar
    Bro!
    The Problem is we want to remove the built in wallpapers to make user unable to change the Wallpaper from settings. Now where is the exact path of these built in wallpaper. so that i could permanently remove it. we have our own designed wallpaper e.g the standard wallpaper.
    This task is very important to be accomplished plz take it serious.
    07-27-2015 06:07 AM
  1. Replies: 2
    Last Post: 01-23-2016, 05:55 PM
  2. Replies: 1
    Last Post: 07-27-2015, 03:05 AM
  3. Replies: 2
    Last Post: 07-26-2015, 10:41 AM
  4. Replies: 1
    Last Post: 07-25-2015, 06:24 AM
  5. Replies: 1
    Last Post: 07-25-2015, 03:03 AM
