Clipboard what does it mean?
A
AC Question
I saved an text to clipboard, but where to see it
T Busby
83
Re: Clipboard what does it mean
Welcome to Android Central! The clipboard stores all of your "copied" text and screenshots.It depends on the brand of phone you are using, however it can be similar on different devices. Press and hold on a text field to access a menu and "clipboard" should appear. Then select your desired text your copied.
