1. AC Question's Avatar
    I saved an text to clipboard, but where to see it
    07-27-2015 03:07 AM
  2. T Busby's Avatar
    Welcome to Android Central! The clipboard stores all of your "copied" text and screenshots.It depends on the brand of phone you are using, however it can be similar on different devices. Press and hold on a text field to access a menu and "clipboard" should appear. Then select your desired text your copied.
    07-27-2015 04:44 AM
  1. Why out of nowhere does My Galaxy Note4 not charge?
    Last Post: 07-27-2015, 04:23 AM
  2. Why does my Samsung S4 keep switching off/rebooting itself?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 07-27-2015, 01:59 AM
  3. Replies: 0
    Last Post: 07-27-2015, 01:44 AM
  4. Replies: 1
    Last Post: 07-27-2015, 01:30 AM
  5. Replies: 0
    Last Post: 07-27-2015, 01:21 AM
