A
AC Question
Toyota Camry Qi charging does not work
I charge my S6 on a Samsung wireless pad every night with the case on the phone and it works perfect. I just purchased a 2015 Toyota Camry with the Qi pad in the car and my S6 won't charge when the phone is connected to the car via Bluetooth and the Toyota Entune App. If I turn the phone OFF and take the case off, the phone charges just fine, but as soon as I turn the phone on, the charging won't work. I also disconnected/unpaired the phone from the car, uninstalled the Entune App and put the phone on the charging pad while it is turned on and now the charging only works intermittently (it basically does not work) but at least it goes in and out of charging rather than not charging at all. The car recognizes the phone when it's on the charging pad which is indicated by an orange light, but it won't charge unless the phone is completely turned off and out of its case. As you might gather, a turned off phone is useless inside the car and doesn't need to be charged to begin with. I called Samsung and I called Toyota and of course neither of those small companies was able to assist me in any shape or form. Please help! Thank you!
