This browser is no longer supported android on browser default of android how can I fix it?
  • Start date Start date
A
AC Question
this browser is no longer supported android on browser default of android how can i fix it?
HI
i meet the problem with my google play link.
message error this browser is no longer supported!
when i use default android browser.
How can i fix it?
Re: this browser is no longer supported android on browser default of android how can i fix it?
HI
How can i fix it?
Welcome to Android Central!
What phone do you have and what version of the OS are you on?
I have the same problem with two androids:
Doogee Latte DG450, android version 4.2.9
and
tablet M-24, android version 4.2.2
Messages have occurred when I was scanning QR codes on some products.
After opening the web address, going to play.google.com it was not possible to easily find the application.
Thanks.
emailists
