1. AC Question's Avatar
    android is so lag and fail ( compare to iPhone ) that I m giving up on android
    I mean Google is a magnificent world no1 company when it is web base ( Google , gmail , Google map , browser chrome , search engine , YouTube )
    but when it comes to android , phone base , it just really too fail , too lag ( at least compare to iPhone , and windows phone don't lag but still not iPhone league )
    giving up on android , still using Google on web base.
    really Google can be so good at web base , but they cannot make it on phone base , why
    iPhone done nothing on web base , and their Mac is not the best , but they do the best job on iPhone , on phone base .
    giving up on android , unless Google all in on android otherwise all out , giving up on android
    07-30-2015 10:35 PM
  2. Jay Sacks's Avatar
    My note 4 does not feel that way. But even if it did lag a bit, I would still choose it for everything else it does well.
    Sent from my SM-N910V using Tapatalk
    07-30-2015 10:49 PM
  3. twin100's Avatar
    install nova launcher prime on (samsung/touchwiz phones) to fix the phone lag.
    07-31-2015 01:33 AM
  4. BooBooth's Avatar
    What kind of Android devices are you using now? Try to get a flagship device. Android even has many 8 core processor devices and 4 GB RAM, and with the development of Android OS, things become different. Android 5.0 is much more smooth than those versions under 4.4. Also you need to notice is that lots of Android devices didn't get a great optimization with its hardware. Personally I think Galaxy S6 or those top hardware devices won't make me disappointed.
    Golfdriver97 likes this.
    07-31-2015 04:11 AM
  5. ToolWiz Privacy's Avatar
    You can boost your phone by releasing memory. Many 3rd party application can help you with this problem. Moreover, some applications can even help you to stop others apps from auto start and running in the background, which can greatly extend battery life.
    07-31-2015 08:42 AM
  6. Golfdriver97's Avatar
    Actually, the reverse is true. Android likes having RAM full, and processes running. If you start killing these, Android will just restart them, thus draining the battery more than it should. http://forums.androidcentral.com/amb...m-android.html
    As for the OP, to echo one of the above comments, which device are you using? There is a big difference between the S6, M9, or G4 versus a ZTE Blade, or something like that.
    Laura Knotek likes this.
    07-31-2015 08:51 AM
  7. ToolWiz Privacy's Avatar
    It’s not Android that restart the apps, but the apps themselves. Like back in windows times, a malware can’t be killed because it always starts itself. But it’s not system’s fault. Today, many app developers actually want to stay in RAM as long as possible and try everything to make their apps auto start. The only way for users to kill the apps running in background is to root the device and then use 3rd party app to turn auto start off.
    08-02-2015 12:55 AM
  1. Lag on call screen and Play Store connectivity issues
    By Iskaral in forum ASUS ZenFone 2
    Last Post: 08-05-2015, 12:41 PM
  2. How do I stop the keyboard sound on the S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 07-31-2015, 07:37 AM
  3. Replies: 0
    Last Post: 07-30-2015, 10:28 PM
  4. 5.1.1 Android version Messaging
    By AlphaBee in forum Ask a Question
    Last Post: 07-30-2015, 10:08 PM
  5. Is the Note 4 compatible with DoubleTwist?
    Last Post: 07-30-2015, 09:31 PM
