1. AC Question's Avatar
    I used to have an ability to determine whether I wanted a small medium or large image for sending. Do I have that on my android?
    07-31-2015 10:23 AM
  2. srkmagnus's Avatar
    Open the camera settings and look for the image quality settings. You can adjust the quality of the image. Also, most text messaging applications will compress images that you send. If yours is not doing it automatically, go into the settings to see that it's enabled and/or download a third-party app that allows that setting.
    07-31-2015 11:57 AM
  1. Replies: 1
    Last Post: 11-16-2015, 03:30 AM
  2. Replies: 2
    Last Post: 07-31-2015, 12:07 PM
  3. LG L90 is not turning on with battery??
    Last Post: 07-31-2015, 12:03 PM
  4. Replies: 4
    Last Post: 07-31-2015, 11:39 AM
  5. Replies: 1
    Last Post: 07-31-2015, 10:22 AM
