1. AC Question's Avatar
    the phone wont turn on at all three days and still not turning on, I put it on the charger for about half hour, didn't come on, pressed the little button, still didn't come on, not sure what to do besides trash it now, any help
    08-03-2015 05:13 PM
  2. dirk de boer's Avatar
    try to reset, how? Hard to say if you don't mentioned your device model if that doesn't work then try to reflash your device with fabric software
    08-03-2015 07:08 PM
  1. Can I get some help with a security setting problem on 5.1.1 Lollipop?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 04-25-2016, 01:12 PM
  2. Standby Time On 5.1.1
    By razza1987 in forum Samsung Galaxy S6
    Last Post: 08-14-2015, 09:45 PM
  3. Replies: 2
    Last Post: 08-12-2015, 09:33 AM
  4. How do I get talk to text working again on my Blu Vivo?
    By AC Question in forum Blu Android Phones
    Last Post: 08-03-2015, 04:54 PM
