1. AC Question's Avatar
    I've tried checking the sd card in my desk top and got nothing not even a drive open for it. I've switched batteries with a fully charged one, nothing. HELP!
    08-04-2015 12:00 AM
  2. Rukbat's Avatar
    If it's a SanDisk card, go to SanDisk microSD Tech Support and talk to a tech (upper right corner of the screen - live chat). They'll replace bad cards within warranty (the shortest warranty is 5 years, so you should be covered).
    If it's another manufacturer, contact the seller or the manufacturer and try to get it replaced. If the desktop can't even see that it's connected, there's nothing you can do with it. (You looked in Administrative Tools/Computer Management/Storage/Disk Management to see if it shows up, right? (If it's formatted as something Windows can't read, it will show up there, but not as a drive. You can format it as FAT32 (or exFAT if it's 64GB or larger) from Disk Management.
    But the phone should see it as something and tell you that you have to format it - unless it's a bad card.
    mc13020011 likes this.
    08-04-2015 01:54 PM
  3. mc13020011's Avatar
    Yes, second option is the best choice. A comprehensive solution by Rukbat.
    08-04-2015 02:01 PM
  1. Replies: 2
    Last Post: 11-16-2015, 07:55 AM
  2. Replies: 13
    Last Post: 11-15-2015, 06:08 PM
  3. How do I unlock/disable the fingerprint technology on my S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 08-04-2015, 07:12 AM
  4. Replies: 1
    Last Post: 08-04-2015, 12:18 AM
  5. Why does my snap chat notification turn itself off?
    Last Post: 08-03-2015, 11:20 PM
