A
AC Question
Accidentally uninstalled print spooler
I accidentally uninstalled print spooler from my ZenFone and I can't find which one is it in play store. It kept stopped working so I tried restoring to the original version, I thought it only uninstall the updates. I can't save the page to pdf. I tried with some apps to save pdf but it doesn't work properly
