1. AC Question's Avatar
    How do I cut and paste words from an email to a text?
    08-06-2015 03:18 PM
  2. Dirt bike Mike's Avatar
    Well depending on your phone say you're sending a text message and you type a text message you hold your finger down until it says copy and then and then wherever you want to paste it just hold your finger for a second on that area and a little box will come up that says paste and that's it I hope this helps you out I have a droid Maxx turbo and that's how I do it online works on emails text messages virtually you have to type anything. Well I hope this helps you out and answer the question if not call your phones carrier and they'll be able to help you under tech support
    Thank you from Mike Sears
    anon8380037 and jlmii like this.
    08-06-2015 03:44 PM
  3. anon8380037's Avatar
    Hello. Welcome to Android Central.
    also just slide the end bars to where you want to cut or copy, and tap the cut or copy icon.
    I use the Clipper app which I recommend as it stores 20 clips, so the icons in this shot may be those.
    Laura Knotek and etyrnal01 like this.
    08-06-2015 03:57 PM
  4. jlmii's Avatar
    Thanks for your help
    08-07-2015 01:02 PM
  5. anon8380037's Avatar
    08-07-2015 03:48 PM
  1. "Hey is that an Apple Watch?"
    By Proudnerd in forum Samsung Gear S
    Last Post: 08-13-2015, 10:05 AM
  2. Where is auto brightness on an my S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 08-07-2015, 11:12 AM
  3. Is it possible to block certain phone numbers on the Nexus 6
    By mothershipload in forum Google Nexus 6
    Last Post: 08-06-2015, 06:15 PM
  4. What the heck is this icon?
    By dndtom in forum LG G3
    Last Post: 08-06-2015, 03:47 PM
  5. Replies: 0
    Last Post: 08-06-2015, 02:29 PM
