1. AC Question's Avatar
    want to switch a Samsung galaxy s3 phone so it will work with different provider
    08-07-2015 04:48 PM
  2. Crashdamage's Avatar
    First the phone must be unlocked by the p;resent service provider. If the phone is paid for or you have fulfilled any contract, they should do this with no problem. If you owe on the phone or are still under contract you'll have to work that out wiith them or maybe your new provider wil pay it off. If you try to just take of with the phone while owing money, they will blacklist the phone's IMEI number, making it unusable.
    Second, the phone must be compatible with your new provider of choice. You'll need to know the phone's sub-model number. Then go to this site to find out if the phone will work:
    WillMyPhoneWork.net - Check if your phone works on a network
    08-07-2015 05:20 PM
  1. Replies: 2
    Last Post: 08-08-2015, 01:31 AM
  2. Replies: 1
    Last Post: 08-08-2015, 01:25 AM
  3. S memo did not sync from S4 to Note4
    Last Post: 08-07-2015, 04:21 PM
  4. How do I get my Google Play app that has disappeared from my Android?
    By Lashawn Sayles in forum Google Play Store
    Last Post: 08-07-2015, 04:15 PM
  5. N7 Streaming Internet Radio Stops After 10 to 15 Minutes
    Last Post: 08-07-2015, 03:54 PM
