A
AC Question
VZW Update installation stalled for over two hours.
Downloading latest VZW note 4 update and the installation has stalled at about 1/4 of the way through for over two hours? The update downloaded normally. I started the installation and it has been stuck on approximately 25% (doesn't list an actual percentage) for over two hours. The little android guy's antennae are still moving and the blue in the box is still spinning so it's not that the screen is frozen. What can I do? Any way to do a factory reset?
