1. AC Question's Avatar
    I accidentally deleted the shortcut bar on tap to add priority sender on the message app of my Galaxy S6, now I want it back...
    08-12-2015 10:27 AM
  2. srkmagnus's Avatar
    Did you check through the app settings to see if you are able to add it back?
    08-12-2015 10:45 AM
  3. drags_1973's Avatar
    yes but it doesn't show the option, I hope you could help me find a solution, thanks.
    08-12-2015 08:17 PM
  1. What is a good Wi-fi calling app?
    By longtallsam in forum Android Apps
    Last Post: 10-09-2015, 10:58 PM
  2. How do I root my Samsung galaxy Note Edge sm-n915g?
    By Rajdeep_442 in forum Samsung Galaxy Note Edge
    Last Post: 08-14-2015, 08:07 AM
  3. Way to adjust display color temperature?
    By Blacklac in forum Samsung Galaxy Note 4
    Last Post: 08-13-2015, 12:49 PM
  4. How do I give my app administrator permissions?
    By socialsipn in forum Android Apps
    Last Post: 08-12-2015, 03:38 PM
  5. Replies: 1
    Last Post: 08-12-2015, 10:50 AM
