how to get rid of popup on samsung( se for android is disabled)
hello , please help, i cant get rid of a popup saying (se for android is disabled,please tap here) , i got a samsung galaxy prime, and when i long press this notification for app info, its directing me to "knox notification manager' if you force stop it,it keeps popping and popping again, please help me its really annoying T_T
Re: How do I get rid of a popup on my Samsung( se for android is disabled)?
Hi, I have been reading a lot of stuff about this problem and the only solution for me was to get root access with the app "Kingo ROOT", then to install "Titanium BackUp Pro" and to freeze all Knox apps.
You can try, it works for me :)
My mobile samsung galaxy showing me again and again Se for Android has been off. tap here for more information so please provide me solution of this problem so i can stop this pop up massage
